USG60W FW 4.38
Wolfgang
Wolfgang Posts: 39 image  Freshman Member
edited April 2021 in Security
Hallo,
have someone already installed the 4.38 Version?
On which WK-Build is the Firmware based or the fixes incorporated?
Thx
Wolfgang
  • itxnc
    itxnc Posts: 102 image  Ally Member
    First Comment Friend Collector Seventh Anniversary
    The release notes have all the fixes (link in the firmware screen). There's a bunch. I have it on a USG110 and a couple USG40s. No issues so far.
  • Wolfgang
    Thx.
    I have also installed on one USG40W, let us see what happens.
  • ChrisGer
    ChrisGer Posts: 206 image  Ally Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    Update on a USG60W today proceeded "frighteningly wise" without any errors or side effects (today).
  • Maveloth
    Maveloth Posts: 6 image  Freshman Member
    edited May 2020
    I've installed it since 4 days on my USG60W and no issue, but this morning I've had a warning on my log:
    <div>Port 4 is down!<br></div><div>Port 4 is up!</div>
    The problem is that the port 4 has no cable connected...
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited May 2020
    @Maveloth
    Have you ever seen "Port 4 is up" from console message?
    Can you private message your configuration for monitoring?
    @Wolfgang
    The v4.38 which is based on v4.35 and included some fixes and enhancement.
    You can check release note to get more complete information.
