BWM TCP ack changes at V4.50
Mario
Mario Posts: 109  Ally Member
Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Sixth Anniversary
edited April 2021 in Security
Hi
in the changelog of V4.50 at page 17 is some news about BWM:
[ENHANCEMENT][BWM] Let TCP ack packets can be managed by BWM
function. Add CLI command to enable/disable this enhancement.
(eITS#180700033, 200200602)
But I don't find a description or a command in the CLI reference guide.
@Zyxel: can you provide some information?
Mario
    PeterUK Posts: 3,892  Guru Member
    edited May 2020
    its
    configure terminal
    Router(config)# bwm control-tcp-ack
    By default (for some reason) when you download small ack packets are sent back bypassing the BWN but with bwm control-tcp-ack they are not.
    This is useful when you set a egress limit and don't want to go over the limit much were as without the  control-tcp-ack when doing a download and upload at the same time you go over the limit.
  • Mario
    Thanks, I'll try it out.
