Need instruction to setup static link aggregation between Zywall 310 and GS2210
I have a Zywall 310 and a GS2210 switch. Both on the latest firmware. I would like to setup a static LAG between the two devices to increase available bandwidth. I would like to connect Zywall ports ge4 and ge5 to GS2210 ports 1 and 2.
How would I configure each device.
Thanks in advance.
Thanks in advance.
I have configured and tested it before, the below guides as your reference.
https://www.youtube.com/watch?v=1DLQRi64sp0
@Jeremylin - the video you linked to sets up the USG1100 LAG as 802.3ad - dynamic link aggregation (LACP).
I am looking to set up a static LAG between the USG and the GS2210 switch.
I am trying to understand if I should use balance-alb as the LAG mode on the USG. If so, do I configure the switch to use source and destination MAC address (src-dst-mac) or something else.0 -
“Interface Type” to “Internal”, type in a name and choose the appropriate security “Zone”.
Select “Mode” to “balance-alb”
Choose the ports to be a member of your LAG, and configure IP on “IP Address Assignment” and “DHCP Setting” and DHCP settings of your LAG interface.
On switch just follow as I wrote before. The criteria you configure the default one(src-dst-mac) should be accepted, since this is traffic distribution algorithm used in trunk group.
- 441 Beta Program
- 532 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
