[NEBULA] Different VLANs for 2 SSIDs
WLN_Net_Support
How do i configure the Zyxel AP NWA1123v2 to advertise 2 SSIDs that are different VLANs?
Hi @WLN_Net_Support,
For example if there are two SSIDs , one is "Employee" SSID with VLAN 10, the other is "Guest" SSID with VLAN 20.
1. Go to Access point > Configure > SSID_overview > Authentication > Edit
2. Fill in the VLAN ID to 10 for SSID "Employee" and then back to SSID overview page to save the changes.
3. Fill in the VLAN ID to 20 for SSID "Guest" and then back to SSID overview page to save the changes.
Note: please also confirm that other related devices such as: DHCP server/gateway, switches and so on have corresponding VLAN10 and 20 settings.
Hope it helps
Thanks!0
- 588 USG FLEX H Series
- 477 News and Release
