BWM TCP ack changes at V4.50
Hi
in the changelog of V4.50 at page 17 is some news about BWM:
[ENHANCEMENT][BWM] Let TCP ack packets can be managed by BWM
function. Add CLI command to enable/disable this enhancement.
(eITS#180700033, 200200602)
But I don't find a description or a command in the CLI reference guide.
@Zyxel: can you provide some information?
Mario
its
configure terminal
Router(config)# bwm control-tcp-ackBy default (for some reason) when you download small ack packets are sent back bypassing the BWN but with bwm control-tcp-ack they are not.
This is useful when you set a egress limit and don't want to go over the limit much were as without the control-tcp-ack when doing a download and upload at the same time you go over the limit.
Thanks, I'll try it out.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
