VPN SSL
Institut_FIMAC
Institut_FIMAC Posts: 3  Freshman Member
edited April 2021 in Nebula
Have you planned to add VPN SSL fonctionnality ?
  • Zyxel_Chris
    Zyxel_Chris Posts: 728  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    It's currently not in our roadmap, have you consider the L2TP over IPSec, the data also encrypted and it's supported on every PC or mobile device, the user don't need to install the third party application.
    /Chris
  • Institut_FIMAC
    edited February 2019
    The client and router configuration is more simple and your licence rule don't need to buy licence for SSL.
    +1 for add SSL in your roadmap.
    Thanks.
  • [Deleted User]
    [Deleted User] Posts: 3  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    I also would like SSL VPN to be enabled in Nebula, especially for the new USGFlex firewall. There are a lot of businesses that require SSL-encryption because of safety and other compatibility issues.
  • jacob123
    jacob123 Posts: 11  Freshman Member
    Zyxel Certified Network Administrator - Security First Comment Fifth Anniversary
    I made this wish last year, but still would like this option, some customers have issues with using L2TP over IPsec, due to ISP setup.
Nebula Tips & Tricks
