[NEBULA] Difference between the NSG series and the new USG FLEX series?
fnkylove
fnkylove Posts: 2 image  ZCNE Certified
First Comment ZCNE Nebula Level 1 Certification - 2019 First Anniversary
edited April 2021 in Nebula
What will be the main differences between NSG --> USG FLEX gateways.
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    I would like to know too.
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi All,
    Thanks for your attention to our Nebula device.
    The NSG and USG Flex main difference as below:
    USG Flex will have:
    1. NebulaFlex (hybrid mode).
    2. Security profile synchronization to multiple sites.
    3. Supported more than 2 WANs.
    4. Much better UTM performance and leveraging ATP's malware protection technology.
    Hope it helps.
    Jason
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    What models support USG Flex?
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    USG Flex currently has 3 models please refer to the following link and be aware that USG Flex is not support cloud mode yet.
  • Wicky
    Wicky Posts: 42 image  Freshman Member
    Ideas master First Comment Friend Collector Fifth Anniversary
    Hi Chris,
    I was just wondering when similar Nebula GW will become available ? The new Flex models are much more powerful with a much lower power envelope. I like the Nebula stuff but I feel they are always a bit behind. I’m looking into a new router/gw and eying on the nebula stuff as I already have the AP’s. Also there you see a similar evolution.
    With the new Flex models it becomes feasible to have a low power high performance setup at home without having to install it somewhere to avoid the noise of fans making you deaf :)
  • Zyxel_Chris
    Thanks for your support. :)
    In current stage USG Flex only support standalone mode, the schedule of cloud mode will be on next year of half.
  • Wicky
    @Nebula_Chris
    Do you mean second half of the year ?
    is there an update foreseen for the pure Nebula stuff ? I would like to replace my current router (Draytek), Draytek fanless POE at and hp switch by some nebula stuff. Certainly on the Poe a good 8 port fanless option is something hard to find ?
  • Zyxel_Chris
    Hello @Wicky
    It will be on the first half of the year, 2021.
    Thanks again for your interest in Nebula products.  B)
    For the replacement on Draytek switch I will suggest GS1920-8HPv2, here is the link for your reference and please stay tune of USG Flex on cloud~?
  • Pook
    I personally don't go for any locally managed zyxel kit anymore, I have a huge pile of various USG's building up that have been replaced with Nebula NSG's.
  • Gareth
    Gareth Posts: 12 image  Freshman Member
    I much prefer the simplicity of the Nebula kit from an IT point of view as its far simpler to replace and configure for remote users, workplaces etc but the USG seems far superior in terms of specs, performance and throughput. Would be nice if we had the single point of management of Nebula with the features of USG.
Nebula Tips & Tricks
