[NEBULA] Spotify Connect blocked by Content Filtering
blechkiste
blechkiste Posts: 14
image  Freshman Member
edited April 2021 in Nebula
Hi
Even without any category being selected, NSG is preventing me from successfully select any Spotify enabled loudspeaker from the Spotify app in order to listen music on it. Disabling Content Filtering immediately resolves the problem.
There's no information in the Event logs on the NSG. I have captured the traffic on NSG for LAN1 and WAN1, merged them in Wireshark and started with the troubleshooting. I've pulled the following HTTP hosts from the conversations and added them to the white filter on NSG which did not help:
*.edgesuite.net
*.akamaitechnologies.com
*.spotify.com
*.googleusercontent.com
Is there any possibility to debug the content filtering mechanism on the NSG? Clearly, the issue is related to that functionality. Appreciate any help.
Regards
Walter
  • Zyxel_Chris
    Zyxel_Chris Posts: 739
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    image  Zyxel Employee
    To All,
    The root cause is because Spotify use SSLv3 communicate with each clients, which considered is vulnerable and block by CF, if anyone who experience this issue please just leave the message here, I will help you.?
    /Chris
«1
  • Zyxel_Chris
    Hello @blechkiste
    Welcome back to the community.
    May I know is there any content filtering entry in Gateway>NSS Analysis?
    Since I cannot reproduce the issue, therefore I'd like to private message you about the Org. information please be aware of your Inbox message.?
    /Chris
  • blechkiste
    Thanks, Chris. I’ve opened a support case.
    wrt NSS: no further information visible either.
    Regards
    Walter
  • Zyxel_Chris
    To All,
    /Chris
  • Dave_M
    Dave_M Posts: 1
    Still no solution? Having the same problem. Denon Spotify player is visible but the connection from my phone is never established.
  • blechkiste
    Hi Dave
    Zyxel fixed it directly on my NSG. Reach out to Nebula_Chris. You'll probably need to open a support ticket too.
    Regards
    Walter
  • Zyxel_Chris
    @Dave_M
    Have replied you via private message please check your inbox message.?
  • Juan_SUS
    Juan_SUS Posts: 1 image  Freshman Member
    Having the Same issue googleusercontent.com is blocked with the MSG:
    Websites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for doc-0o-6k-apps-viewer.googleusercontent.com. The certificate is only valid for the following names: dnsft.cloud.zyxel.com, *.dnsft.cloud.zyxel.com
  • ivers
    ivers Posts: 45
    First Comment First Answer Friend Collector Fifth Anniversary
    edited May 2022
    @Juan_SUS
    Did you try to put this domain in white list on content filtering?
  • tesagig
    tesagig Posts: 60
    image  Ally Member
    just wondering whether this could apply to my USG 100 Flex?
    Fundamentally, "Spotify Connect" does not work for me on my Bluesound Node.
    1.) If I navigate though BluOS to Spotify the Spotify app indicates that it is trying to connect to my Node but never succeeds.
    2.) If I click on airplay within spotify and select Node it works ( but I
    like to use "Spotify connect" to not be dependent on ipad after music
    selection)
    So, I can play spotify on my ipad, but not on Bluesound using "Spotify connect"
    I have the spotify app enabled on my USG on the outgoing traffic.
    Local traffic is wide open.
  • tesagig
    tesagig Posts: 60
    image  Ally Member
Nebula Tips & Tricks
