Does DCS consider non-wifi interference ?
Wicky
Wicky Posts: 42 image  Freshman Member
Ideas master First Comment Friend Collector Fifth Anniversary
edited April 2021 in Nebula
i have some very strong interference in channel 1 (2.4ghz),  non-wifi. I have seen the ap hopping to this channel although there is strong interference.
  • Wicky
    Hi Dean,
    So my two ideas about RF scanning (I have seen this feature on another brand, although this AP was not accessible during the 5 min scan period) and customization of channel set (instead of default 3 or 4 channel deployment) are more relevant now as DCS is not able to tackle a channel with heavy interference.
    Regards,
    Dirk
  • Zyxel_Dean
    Zyxel_Dean Posts: 237 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    edited November 2017
    Hi Dirk,
    Totally agree, the solution for non-wifi interference at this stage is limited to configurable channels which this feature is in the roadmap already, currently scheduled in 2018. For the time being you may want to set static channel to avoid interference.
    edited on 11/20 ,
    Additional information, the non-wifi interference scanning feature is limited to hardware capabilites in which our APs as of current don't support it due to chipset limitations.
    Dean
Nebula Tips & Tricks
