[NEBULA] Alias for Nebula device and a device Name for Add device by Nebula APP
Hi @flottmedia,
Yes, your understanding is right about the "Editing question".
May I know if you could edit the hostname of (2) again to verify if the problem is solved and the client page is synchronized? Because before/after the fixed, the edited box in the client page is not affected, it means the hostname still remain the same.
For the (3), yes, DHCP lease time "Forever" will keep the DHCP table forever, but the client will get different IP if the NSG rebooted, because the DHCP table will be flushed out. As I've checked the NSG has rebooted on May 31 after the firmware upgrade, so it could explain why (3) gets new IP address.
And for the (1), I would like to inform that NSG client page is MAC based mechanism after manually edited the hostname on NCC. I've made a test and verified that it works fine.
Example:
PC MAC: AA, IP: 192.168.10.1, NCC edit hostname: PC-A => client page display = PC-A
PC MAC: AA, IP: 192.168.10.2, NCC edit hostname: PC-A => client page display = PC-A
About the another question for deleting the history client, it is not possible currently, I'll create a post in the idea section to let other user leave a like and comments.
Jonas,Jonas,5 -
Thanks for clarification @Nebula_Jonas. Was quite a bit of manual work to get the lost names back, but at least I can confirm that the naming mechanism now seems to be consistent between GW, AP and SW clients.
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
