Jason
[NEBULA] Difference between the NSG series and the new USG FLEX series?
I would like to know too.0
Hi All,
Thanks for your attention to our Nebula device.The NSG and USG Flex main difference as below:
USG Flex will have:1. NebulaFlex (hybrid mode).
2. Security profile synchronization to multiple sites.
3. Supported more than 2 WANs.
4. Much better UTM performance and leveraging ATP's malware protection technology.
Hope it helps.0 -
What models support USG Flex?
USG Flex currently has 3 models please refer to the following link and be aware that USG Flex is not support cloud mode yet.
Chris
Hi Chris,
I was just wondering when similar Nebula GW will become available ? The new Flex models are much more powerful with a much lower power envelope. I like the Nebula stuff but I feel they are always a bit behind. I’m looking into a new router/gw and eying on the nebula stuff as I already have the AP’s. Also there you see a similar evolution.With the new Flex models it becomes feasible to have a low power high performance setup at home without having to install it somewhere to avoid the noise of fans making you deaf1 -
Thanks for your support.In current stage USG Flex only support standalone mode, the schedule of cloud mode will be on next year of half.
Chris
Nebula_Chris said:Thanks for your support.In current stage USG Flex only support standalone mode, the schedule of cloud mode will be on next year of half.
@Nebula_ChrisDo you mean second half of the year ?
is there an update foreseen for the pure Nebula stuff ? I would like to replace my current router (Draytek), Draytek fanless POE at and hp switch by some nebula stuff. Certainly on the Poe a good 8 port fanless option is something hard to find ?
I personally don't go for any locally managed zyxel kit anymore, I have a huge pile of various USG's building up that have been replaced with Nebula NSG's.
I much prefer the simplicity of the Nebula kit from an IT point of view as its far simpler to replace and configure for remote users, workplaces etc but the USG seems far superior in terms of specs, performance and throughput. Would be nice if we had the single point of management of Nebula with the features of USG.0
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
