Connection check Disabled
Did you select the VPN tunnel before clicking the button ?
What kind of VPN scenario are you using? Is it site to site with dynamic peer? or IKEv2?
It would be helpful if you can take a video of the symptom of the issue on the monitor page of VPN connection.
Hi @dpipro,
The Connection Check button is grey out before selecting a VPN tunnel.
You could follow jasailafan’s instruction to share us related information if it is still unable to click.
@Jasailafan, Thanks
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
ZCNE Certified
