deleted the registered AP on Nebula, and have reset the AP. Not web gui access locally
tnitech
tnitech Posts: 2  Freshman Member
edited April 2021 in Nebula
I got the same issue. I deleted the registered AP on Nebula, and have reset the AP. Now I am not able to access the AP locally or on Nebula. What should I do? Many thanks!
  • Zyxel_Freda
    Zyxel_Freda Posts: 397  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    edited July 2020
    Hi @tnitech ,
    May I know what's the AP model name and the LED status? After you reset the AP to default setting, the AP would get an IP address from the DHCP server. May I know did the AP get the IP?
    Otherwise, if there's no DHCP server, the AP will be the default IP 192.168.1.2, and you can set the computer to the same subnet to access it.
Nebula Tips & Tricks
