Create a MAC Filtering in speciefied port
Infotecnika
Infotecnika Posts: 18 image  Freshman Member
edited April 2021 in Nebula
Hi! We want to create a MAC Filtering rule for specied fort of a switch (GS1920-24P).  The target is to permit only one MAC address to be connected en each port.
P1 -> Allow only MAC AXXXXXX
P2 -> Allow only MAC BBXXXXX
P3 -> Allow only MAC CCXXXXX
Well, y tried with ACL-> "Customization Rules" , but not sure how to create the rule as we can,t select the affected port (it,s greyed).
What are we doing wrong?
Thank you!
  • Infotecnika
    Hi!
    Much thanks for yor explanation.  I,ll see the option to install radius server or your workaround proposal.
    Regards.
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    Hi @Infotecnika
    Keep in mind that MAC Address can be easily spoofed.
    Several ports could need to use the same MAC Address (for example multicast, VRRP, ...)
    I suggest that your security is not based solely in the MAC Address filters.
    Enjoy
  • Infotecnika
    Much thanks for your infor Alfonso,  but we,re making it for IP TVs  and does not have any additional authetication protocols (...just macaddress or vendor_id etc)
    Best regards.
Nebula Tips & Tricks
