Domain Zone Forwarder
Hi @Nebula_Chris
I have the DHCP setting set on
1st DNS NSG
2nd DNS none
3rd DNS none
then on the gateway settings, I have it set as per picture I've previously attached.
is this configuration correct or in order to use other DNS I need to set it on the DHCH page?0 -
Hi @CarloJust configure the prefer DNS server IP in LAN interface for instance1st: 1.1.1.12nd: 1.0.0.13rd: 8.8.8.8Then can work.
Hi @Nebula_Chris
I have configured the DNS in the IP Lan setting as suggested thanks.
however, can you please clarify what the Domain Zone Forwarder does in the gateway setting?0 -
Hi @CarloIt's usually for the user who has his/her own domain server (in privacy), then can use this approach to reply the domain request.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
