XGS1930-52HP 10G port cannot link up
D_Shadow
D_Shadow Posts: 18 image  Freshman Member
First Answer First Comment Friend Collector Fourth Anniversary
edited April 2021 in Nebula
I've bought 2 XGS1930-52HP, while connecting both switches with dac cable on port 49~52, it won't link up. I'm pretty sure that the dac cable is in good condition, because I've tested it on other device. Is there anyone here also encountering the same problem? Thanks in advance.
D,
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 313 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @D_Shadow,
    You will need to access the local web GUI of the switch and change the port media type to "dac10g" mode to be able to link up using dac cable, as figure below:
    WEB GUI > Basic Settings > Port Setup
    Hope it helps.
    Jonas,
    Jonas,
  • Zyxel_Jonas
    Hi @D_Shadow,
    Hope it helps.
    Jonas,
    Jonas,
  • D_Shadow
    Hi Jonas,
    At last, the link is up now.
    Thanks for the answer.
    Just wondering, why it cannot be configure on Nebula?
    D,
  • Zyxel_Jonas
    Hi @D_Shadow,
    Thanks for the suggestion.
    I would like inform that, it was already included on our roadmap.
    Please stay tuned.  :)
    Jonas,
Nebula Tips & Tricks
