since there is no visable reset button on the WAC6552D-S, how do you reset the device to factory def
CAWorldWiFi
I can't find a way to reset the WAC6552D-S to factory default once the device is registered to the Ncc
Hi @CAWorldWiFi,
There's no hardware button on WAC6552D-S to do the factory default. Once it's registered on the NCC and online, it can be reset to default by removing the AP from the site or the organization. Otherwise if the AP is just registered to the site but not online yet, you can reset it to default via ZON utility or apply system-default.conf configuration on the AP web GUI.
Here is the ZON utility download link for your reference.
https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
