Locked out of USG210
It looks very similar to this issue: https://businessforum.zyxel.com/discussion/1393/locked-out-of-my-own-usg110
The password did not have a $ but started with '
I have a copy of startup-config.conf but is there any way to get back in without having to factory reset?
Hi @jw708,
If you have the latest backup configuration file "startup-config.conf", search for the following CLI.
username admin encrypted-password $4$encryptedpasswordencryptedpassword$ user-type admin
Then set a new password and replace the following CLI with the original one.
In this example, 12345678 is the temporal password.
Save and rename startup-config-back.conf. Upload this configuration file to device and apply it.
5
Hi @jw708,
5 -
Thanks @Zyxel_Emily that worked.
I still find this whole situation absurd and have not appreciated having to spend time at the weekend to be physically next to the device to resolve this. As others have suggested, this has been enough for me to avoid using Zyxel products again in future.
Thanks.
Hi @jw708,
Set a new password ''a12345 for admin after the password is expired when using the latest firmware, and I can successfully login as admin with the new password ''a12345.
You can upgrade to the latest firmware and try it again
https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version
- 588 USG FLEX H Series
- 477 News and Release
