ATP Email Security kills *.zip files
Michael_I
Michael_I Posts: 46 image  Freshman Member
edited April 2021 in Security
the zip-files scanned by the atp can´t be opened. I think the atp kills the *.zip file while scanning.
  • Michael_I
    I checked it again. It only happens when the zip file, scanned by email security, has a passwort. Email Security destroys the zip-file, so it can be opended in Outlook.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Is anti-malware also enabled on ATP?
  • Michael_I
    Yes, could this be the problem?
  • Zyxel_Emily
    Hi @Michael_I,
    ATP cannot decompress password protected files.
    When "Destroy compressed files that could not be decompressed" is selected, ATP deletes compressed files that use password encryption.
    You will find the warning message in the log.
    Hence, disable "Destroy compressed files that could not be decompressed" and try it again.
