Can't log in need help!!
PeterUK
PeterUK Posts: 4,264 image  Guru Member
edited April 2021 in Security
so I upgraded my VPN300 to 439ABFC0ITS-WK32-r95472 I put in my password it then asks my to change my password which I did I then tried to log in with the password and it just throws me back to the login screen. I cleaned my browser history same thing.
I then did a reset and same problem!
Felling really sorry for myself for upgrading now :(
Please tell me and how there is a way to change the active firmware.
    edited August 2020
    crisis averted!
    Thanks you PuTTY SSH and zyxel cli_reference_guide
    For any having trouble like me
    configure terminal
    show version
    set firmware boot number 1 or 2
    firmware 439ABFC0ITS-WK32-r95472 is bad!
  • Zyxel_Emily
    We apologize for the inconvenience.
    The root cause is the multilingual of the web GUI.
    We will build the firmware again and release it to you later.
    Thanks for the quick fix update have just installed 439ABFC0ITS-WK32-r95521 and can get to the GUI :)
