Can't log in need help!!
so I upgraded my VPN300 to 439ABFC0ITS-WK32-r95472 I put in my password it then asks my to change my password which I did I then tried to log in with the password and it just throws me back to the login screen. I cleaned my browser history same thing.
I then did a reset and same problem!
Felling really sorry
for myself for upgrading now
Please tell me and how there is a way to change the active firmware.
Hi @PeterUK,
The new firmware is ready.
I've confirmed that there is no problem accessing the web GUI.
The command "bwm control-tcp-ack" is added.
Apologize again for the inconvenience.
5
crisis averted!
Thanks you PuTTY SSH and zyxel cli_reference_guide
For any having trouble like me
configure terminal
show version
set firmware boot number 1 or 2
firmware 439ABFC0ITS-WK32-r95472 is bad!
Hi @PeterUK,We apologize for the inconvenience.The root cause is the multilingual of the web GUI.We will build the firmware again and release it to you later.0
Hi @PeterUK,
5 -
Thanks for the quick fix update have just installed 439ABFC0ITS-WK32-r95521 and can get to the GUI
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
