ZyWALL USG 100 and VPN tunnel to MS Azure
Hello.
I'm trying to setup VPN tunnel to MS Azure. Everything was gone by this article https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015536&lang=EN .
However, I'm getting errors during connection(see attached screenshot). One of the errors means that Phase 2 cryptography is wrong, but I've tried all supported settings for this. And don't get it fix.
Errors:
Send:[HASH][NOTIFY:NO_PROPOSAL_CHOSEN]
SPI:0x0 SEQ:0x0 No rule found, Dropping packet
I've tried to switch firewall off, tried different cryptography settings on router - and nothing. I've tried to ping 10.0.0.4(my VM in Azure) from router - it is not reachable. But in router interface VPN is shown as connected.
Any ideas?
Errors:
Any ideas?
I've fixed this issue by changing Local/Remote ID type in VPN Gateway settings. Thanks for the guide, helped for this one.Zyxel_Charlie said:the Phase 2 proposal mismatch, please Algorithm and policy are match first
Hello BogdanGn,
On your Log message,
the Phase 2 proposal mismatch, please double check Algorithm and policy are match first.
Secondly, here is an example which is USG establish VPN with MS Azure, so please check it.
Link:
https://drive.google.com/file/d/1XD6vjvlP8qn9kPq3JUhYpvZa1H_zLfwQ/view?usp=sharing
If the issue still occur, please share the server's configuration for checking further.
Charlie0 -
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
