USG310 port role mapping
mrcjrich
mrcjrich Posts: 1 image  Freshman Member
edited April 2021 in Security
on the usg60/40/20 there was an easy way to map port roles to duplicated lan1 across multiple ports. On the USG310 there is no option for that. I tried to create a bridge and add ports into that bridge group but then when i try to assign dhcp for that bridge group it gives me an error message when trying to assign dhcp using the same ip scheme as my lan 1. Is there a way to have the bridge i created use dhcp from my lan 1 config?
    Why not use a switch?
    Give the ports for the bridge a non-usable IP like 127.255.255.1/255.255.255.252...127.255.255.5/255.255.255.252.
    this should stop the error message when doing DHCP for the bridge.
