remote access vpn to other site to site
Best Answers
Yes, you can use remote access VPN (L2TP) to access other site via VPN tunnel.But be aware that to add the policy route in these 2 sites then can work.Policy routing type should select as "VPN traffic"For instance L2TP pool subnet is 192.168.100.0/24 connect to site A (192.168.101.0/24) and site A connect VPN tunnel to siteB (192.168.102.0/24)In site A policy route:src: 192.168.100.0/24, dst: 192.168.102.0/24, Next-Hop: VPN tunnel nameIn site B policy route: to redirect the traffic backsrc: 192.168.102.0/24, dst: 192.168.100.0/24, Next-Hop: VPN tunnel name
6 -
Hello community,Additional configuration approach on this case, you can also simply toggle on "Remote Client VPN" when you are using the Site-to-Site or Hub-and-Spoke application.6
6 -
Thank you chris0
can we use ipsec or should it be l2tp0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
