vlan not found on one AP
Good evening everyone,
I thank in advance anyone who wants to contribute to the solution of my problem:
My problem is the following:
Only on the access point connected to port 02 of the GS1200-5HP can I not acquire the IPs with the DHCP of the firewall and therefore I cannot navigate, I have no problems with the LAN SSID.
Anyone have any ideas about it? Thanks so much.
Network configuration:
ATP100 - GS1900-24HP - GS1200-5HP.v2 - 2 AP NWA1123 on Nebula
_____________________________________________________________________________________
ATP100 P3 P6 ports configured on LAN1, vlan4 is configure as follows
GS1900-24HP connected on P3 of ATP100 with vlan4 tag on port 1 and port 24, this access point connected to the switch works properly on both SSIDs
On GS1200-5HP connected to P6 of ATP100 with vlan4 on port 02 towards NWA1123
The access points have 2 SSIDs, the first with access to the LAN and the second with access to vlan4
NWA1123 controlled via nebula connected on port 01 of the GS1900-24HP
NWA1123 controlled via nebula connected on port 02 of the GS1200-5HP
Best Answers
@Edifica
Welcome to Zyxel community.
It seems to us that the problem is on GS1200 you did not set VLAN 4 tagged-out for the port connecting to ATP (maybe port 1?).
Zyxel_Lucious5 -
Thanks Lucious, actually I hadn't thought about it ... I thought it was enough to tag the firewall port where the Access Point is connected and not the port to the ATP (05), thank you very much. Resolved.
@Edifica
Zyxel_Lucious5 -
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
