Switch off 5GHz Channel
Hello everybody
Can please somebody explain to me, how I can switch of either the 5GHz or the 2.4GHz Channel?
I need for testing just one band.
I'm using a WAC6303D-S.
I couldn't find it in the cloud controller software.
Thank you for your help and all the best
rac
rac
Hi @rac ,
You can edit the SSID broadcast band in Access point> Configure> Authentication. After selecting the SSID on the top of the page, you can select for 2.4GHz band only, 5GHz band only or concurrent operation.
And then click save to apply the setting.
Thanks.0
- 588 USG FLEX H Series
- 477 News and Release
