Wifi 6 APs connecting
halprewitt
Discovered on the WAX650S must have QoS on (WMM) else Wifi6 11ax will not work. Stations (users) fail to connect using the 11ax mode.
Hi @halprewitt ,
It's mandatory to have QoS after 802.11n, so does 802.11ax. So, when you disable the WMM, it would not use 802.11ax mode. May I know that do you have any concern to use it?0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
