GS1900-16 Firmware update
BobStricklin
Having a problem updating firmware on two GS1900-16. When I go to the Web ap page to update firmware the page is not complete. Like it has an issue with Web browser but I have tried several on MAC and Windows.
Also the firmware file 2.60(AAHJ.1)C0.bix I downloaded does not seem like it will work when I try to select this file. Is there another way to upgrade firmware. I tried Zon Utility but this does not find my Zyxel devices after install.
Hi @BobStricklin
Welcome to Zyxel community!!
May I know did you turn off the firewall of your PC?
If no, please disable the firewall and try again
Also, may I know the firmware version you are using on GS1900?
BTW, we will release a new firmware version recently and we suggest installing the latest firmware.
Best regards,
Zyxel_Derrick0
- 441 Beta Program
- 293 Service & License
