NWA-1123
ilove2hope
This device will only connect at 100 mbps. The ethernet indicator color is amber. When I attached another NWA-1123 using the same cable it connects at 1,000 mbps. I attempted factory resetting. Nothing I do makes a difference. How do I correct this?
Hi @ilove2hope
Would you like to connect the AP to another port with another cable line? If it still gets 100Mbps, we suggest to send the AP back to RMA. Please contact your reseller for the procedure.
Joslyn0
- 211 Nebula Ideas
- 545 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 465 News and Release
