WAC6103D-I daily unintended rebooting
We own a single AP of type WAC6103D-I which is connected and managed by our USG110. The USG is running under FW 4.38 (AAPH.0) while the USG AP Management is showing the runtime firmware: V5.40 Patch 2-6.10 Patch 2.
Additionally the list of local installed FWs is showing following AP FWs:
NWA5123-AC: local / v5.40 (AAZY.2)
NWA5123-AC-HD: local / v5.40 (AAZY.2)
At the moment we experience unintended reboots of the AP at least once per day, sometime it happens 2 or 3 times a day. It takes less than 1 minute for completing, but we are always receiving alert logs from the USG. Any ideas?
Hi @USG_User
Yes, please download the DF from the cloud server and apply it first.
You can change the Updating Mode to "Manual". The AP firmware will not be overwritten when you upgrade the USG firmware unless you click the "Upgrade" manually.
Joslyn5
Hi @USG_User
The local AP firmwares are included in the USG v4.38. After upgrading this firmware, these two AP firmwares will also be saved in the USG.
About the WAC6103D-I rebooting issue, could you help to collect the AP diagnostic and provide it to me? We will analyze the logs and try to find the root cause.
Joslyn0 -
Hi Joslyn,Thanks for your reply. I've captured some diagnostic AP data and try to send it by private message.0
Hi @USG_User
I got the diagnostic and found there are some disk logs. It is under analyzing now.
Once there is any progress, I will update it here.
Joslyn0 -
Hi @USG_User
We have fixed the issue and released an AP date firmware. Please download it from the could firmware server. Here are the steps.
Please use SSH or console to login to the USG110.
1. Apply the CLI
Router> configure terminal
Router(config)# capwap firmware-update source 5.40(.2)-DF-2020-03-31
2. Go to CONFIGURATION > Wireless > AP Management > Firmware, and click “Check”. After the available firmware updated, please click “Apply”. The downlading process will be started.
3. After finishing the downloading, go to MONITOR > Wireless > AP Information > AP List. Choose the AP and click the “Upgrade FW” button. The AP will start to upgrade the firmware.
Joslyn0 -
Hi Joslyn,Many thanks for it. I've carried out the necessary steps as described above. The download started as expected but then the USG said "AP firmware download failed. Reason: Device storage is not enough. File name: wac6100"But there should be enough memory available:0
Now, 10 minutes later it seems the USG has autohealed by itself.Do I have to reset the download path for AP firmware downloads back to standard?Further we intend to upgrade the USG to new FW 4.39 soon. Will it keep the new AP firmware or do we have to make the same steps again?0
Hi @USG_User
To not occupy the memory too much, we only save two AP firmwares on the USG. Once it needs to download the firmware from the cloud, it will delete the AP firmware version which is not managed by the USG and download the online AP firmware first.
You do not need to change the AP firmware download path because it will fall back to official link after rebooting the USG. Just do NOT click the check and apply when finishing upgrading the USG firmware. The AP firmware will be kept.
However, if you see the AP firmware is wrong, you can follow the steps to download the AP firmware again.
Joslyn0 -
Hi Joslyn,In the meantime we've updated our USG110 to firmware v4.39(AAPH.0) without checking/applying for new AP firmwares as recommendedNevertheless since a few days after updating the USG, the AP (WAC6103D-I) is being rebooted at least once every day.At the moment the USG is showing the following AP FW screen where now the AP FW v5.40(AAXH.2) is shown instead of v5.40(AAXH.2)-DF-2020-03-31Should I try to download/install the other FW of 2020-03-31 as recommended in your earlier post again? Or should I provide you with diagnostic data collection from the AP?CheersJoerg0
Hi @USG_User
Joslyn5 -
Hi Joslyn,Thanks for your reply. I've done it as recommended and set the update policy from Auto to Manual. DF FW is installed again. The AP rebooted automatically. Now we will see ...CheersJoerg0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
