Own certificate on GS1920 or GS1900-10HP
            Well, it is possible. Too bad, this has to be done over telnet (i.e unsecured communication device).
 Hope official way to perform this change would be possible at some point. 0 0
            Hi @switch
 Thanks for your sharing!
 We have noticed that there might be method of making certificate as you did on GS1900.
 Due to this is not a formal feature on GS1900, we can not guarantee the performance of it.
 Therefore, we do not recommend users to use it.
 As mentioned in the previous discussion, this feature will be added in Zyxel switch except for GS1900 series because it is an entry level managed switch.
 Ryan0
            Hello there,What is the news on this? When can one import SSL-certificates on Zyxel Switches?On what Firmware version will that be (release when?) and on what Switch series will that be feature be?cheers,Francisco0
            Hello @Francisco,The import certificate feature will be launch on XGS4600-32/32F (firmware version 4.60) first this coming December.
 Zyxel_Jonas0
            Why exclude GS1900? Importing certificate worked perfectly fine.
 Actually, since the method I'm using still works -- I'm happy. DO NOT TOUCH
            So, since it is almost the end of 2019, how can I install an certificate on an XGS2210-28HP? 0
            Hi @eddeig For XGS2210 series, the feature will be enhanced in the upcoming firmware 4.70 which is scheduled at 2020 Q3Q4. Zyxel_Lucious 0
            Hello,What is the news on this? when will 4.70 be available and will we be able to import certificates then?0
            Hi @Francisco
 We have a light change to the release schedule of XGS2210 version 4.70.
 It will be released in 2021 Q1.
 Best regards,
 Zyxel_Derrick0
            Hello,It's July 13th 2021... So we are in Q3, right?When will we finally be able to import certificates?This is very annoying and most UNPROFESSIONAL!Francisco
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
