Zabbix - Zywall plugin
Can we plug Zywall logs into Elasticsearch?
@Przemek
As your request,
I recommend that you can use SecuReporter to monitor ZyWall/USG.
You can reference the Secureporter introduction from official Website
https://www.zyxel.com/products_services/Security-Service-Cloud-CNM-SecuReporter/
Charlie0 -
Its making harder infrastructure monitoring. All hardware in company is monitored by Zabbix and now Zywalls will be in different panel. I found Zywall plugin for Zabbix but there is to low details. I think your support for wideused Zabbix will be apprecieted by many admins.
You could download the mib file from official website first.Example for USG110, you can visit this Link to download the MIB file.I think zywall can be monitored or managed via SNMP, basically monitoring tool that supports understanding OID will work.
Also, you should configure SNMP on device
you're like me (luckily I'm not the only one using Zabbix to monitor the on-prem infrastructure)
my first invest was to locate MIB values and convert them to a device modell in zabbix. but this projekt is on hold (depending by the actualy sutuation arround the globe).regards
ChrisGer0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
