2FA over IPSEC VPN not working on ATP Series???
Hi all,
i'have an issue with 2fa service over ipsec vpn on a ATP200 with fw 4.55.
Even if the "ipsec" checkbox is marked in 2FA menu, users can connect to vpn without any other auth. factor.
2FA on a SSL Vpn works well.
Ideas??
Thanks in advance
Ideas??
Thanks in advance
@Fred_77
Can I know did you use Email as 2FA?You can update to the current firmware and see if the issue still exist since we had fixed some 2FA related issues in this version. The fixes will also be included in the upcoming formal release which will be released in Nov.
Link: https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version#latest
Charlie
Hi Charlie, thanks for your reply;
2nd auth. factor is sms0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
