Internet slow
Do you have the newest firmware?
Do you use any of the UTM options?
Maybe try the following firmware found here
https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version#latest
I upgrade the firmware this morning nowI am trying to test it. i use utm option like content filter.0
@LeviPonti
If the content Filter enabled, every packet will be scanned by UTM function may consume the resource and affect the throughput result.
You can try to disable the Content Filter to see if the performance become better.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
