Expert mode and easy mode
Hi @Marko75
You can setup the VPN Wizard again to modify the VPN setting on EZmode.
Hi, I was playing around VPN setting in EZmode, how do I delete it?0
Hi @DannyC,
The settings configured in Easy Mode cannot be modified in Expert Mode. It is to avoid settings conflict between different modes.
To delete VPN settings which are created in Easy Mode, switch to Expert Mode and delete the EZMODE_VPN rule.
If you'd like to configure advanced settings in VPN Gateway and VPN Connection, just start directly with Expert Mode to configure in CONFIGURATION > VPN.
I'm not able to delete EZMODE_VPN_L2TP neither in Easy Mode nor Expert Mode. How to preceed?0
@danieles
The case seems the similar with another thread you created, therefore we could discuss it on below link:
https://businessforum.zyxel.com/discussion/5059/impossible-to-remove-ezmode-vpn-l2tp#latest
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
