Information about FQDN Bug on FW upgrade -> be careful
Mario
Mario Posts: 111 image  Ally Member
Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
edited April 2021 in Security
Hi
I just want to share an important KB from Zyxel about a odd bug with FQDN
Summary: If you use FQDN, read first, update second
BR
Mario
  • Daniel_Habazin
    Daniel_Habazin Posts: 5 image  Freshman Member
    Mario said:
    Hi
    BR
    Mario
    Nice, so that explains why my usg60 needs a help with the hardware button everytime i want to reboot it or change over to the slot 2 firmware.
  • Daniel_Habazin
    Mario said:
    Hi
    BR
    Mario
    well that was fun, after applying the weekly fw the usg60 decided to revert to factory default configuration, i had to find a old u232 and modify it so it would fit the console port so i could see what happened, well managed to restore a backup of the configuration and now i'm back to my old vlans and inet so life's good
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Daniel_Habazin
    Can I know before you upgrade the firmware, did you remove the FQDN first?
    So far, we did not receive any case which is similar as yours.
    Can you private message us your configuration file before upgrading the firmware?
  • Daniel_Habazin
    @Daniel_Habazin
    yes, i followed the instructions fully so i did remove it, i only had two fqdn entries and i didn't even use one of them in the fw rules
  • Zyxel_Charlie
    @Daniel_Habazin
    Can you private message us your configuration file before upgrading the firmware for check purpose?
