Building mesh with Keenetic Giga
Stayer
Stayer Posts: 1 image  Freshman Member
edited April 2021 in Nebula
Hi.
I have Keenetic Giga III as my main router which is connected to the ISP. I want to extend WiFi coverage with NWA1123-ACv2 which is connected to the Giga III with a wire and PoE injector. AFAIK this can easily be done with another Keenetic OS based device: https://help.keenetic.com/hc/en-us/articles/360002155079-Wi-Fi-system?utm_campaign=3.05.C.2.0-1&utm_content=controlpanel/wifisystem&utm_medium=ui_notes&utm_source=webhelp
Is it possible to do so with a NWA1123-ACv2 (acting like a Repeater and listed in Keenetic WiFi system list) ?
Main reason to use the Nebula device is that it's PoE powered.
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    edited November 2020
    It seems the Mesh can be only established within products of the same brand. For each vendor has their proprietary method to establish connections between APs. In the Keenetic article it also mentioned the router can only manage additional "Keenetic" devices.
    The mesh function on Nebula is called "smart mesh",you can use it to connect two NWA1123ACv2 wirelessly. I remember it's also a proprietary function, so only Zyxel products can form up a mesh system.
Nebula Tips & Tricks
