Information about FQDN Bug on FW upgrade -> be careful
Hi
I just want to share an important KB from Zyxel about a odd bug with FQDN
Summary: If you use FQDN, read first, update second
BR
Mario
@Mario
For more information regarding to this symptom, please refer to the link below:
https://businessforum.zyxel.com/discussion/4751/weekly-firmware-support-version-lab-version#latest
Charlie5
@Mario
Charlie5 -
Mario said:HiI just want to share an important KB from Zyxel about a odd bug with FQDNSummary: If you use FQDN, read first, update secondBRMario0
Daniel_Habazin said:Mario said:HiI just want to share an important KB from Zyxel about a odd bug with FQDNSummary: If you use FQDN, read first, update secondBRMario0
@Daniel_Habazin
Can I know before you upgrade the firmware, did you remove the FQDN first?
So far, we did not receive any case which is similar as yours.
Can you private message us your configuration file before upgrading the firmware?
Zyxel_Charlie said:@Daniel_Habazin
Can you private message us your configuration file before upgrading the firmware?0 -
@Daniel_Habazin
Can you private message us your configuration file before upgrading the firmware for check purpose?
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 83 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
