how to let Router OS make VPN with ATP500
Chris8893
Chris8893 Posts: 1 image  Freshman Member
edited April 2021 in Security
ask everyone
how do I Router OS make VPN with ATP500??
using L2TP is better
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Chris8893
    You can check the L2TP configuration of ATP500.
    Click Quick Setup, then click Remote Access VPN Setup build up VPN tunnel with the Wizard.
    Select L2TP over IPSec client (IOS, Windows,Android)
    Fill the required information
    Select the IP Address Pool for the client
    Allow local user to access the device
    If the settings are all correct, click save.
    Also, you need to configure the corresponding setting on MikroTik RouterOS to connect with ATP.
