External captive Portal redirection
Hi everyone,
We have some installattions with NAP and Nebula Pro management. Over this scenario, we have integrated an external captive portal and radius platform
Customers who have our platform integrated with Zyxel Nebula are complaining because the redirection to the external captive portal is not performed correctly.
When the users are associated with the network, the first redirection only sends the parameter "apmac", logically our platform expects to receive all the necessary parameters to display the appropriate captive portal.
if another attempt is made if it does the redirection properly by sending all the parameters.
http://<external-domain>/hotspot/zynebula?apmac=xx:xx:xx:xx:xx:xx&usermac=xx:xx:xx:xx:xx:xx&apip=x.x.x.x&userip=x.x.x.x& ssid_name=SSID_Example& apurl=http: //2.2.2.2/cgi-bin/login.cgi
Do you have any news about this? Could it be because the "beta" functionality has been added to customize the redirection parameters? Should we change any configuration?
Please, we need an urgent response
Thanks in advance
Hi @yomismo2
I tested for the external captive portal, and it redirected automatically with the complete URL.
(modified the MAC address for security issue.)
http://10.214.48.75/?apmac=bc:cf:4f:zz:xx:yy&usermac=0c:54:15:zz:xx:yy&apip=192.168.1.36&userip=192.168.1.37&ssid_name=ZyXEL_test&apurl=http://2.2.2.2/cgi-bin/login.cgi
Could you take a screenshot with the issue URL for the browser and let me the reproduce steps?
Joslyn
Hi Joslyn,
I have updated the firmware version of APs from v6.00 (ABEL 5) to v6.10 (ABEL 8), and it seems that to be working properly. Could this be the solution or a temporary issue?. Please, tell us to notify our clients.
Hi @yomismo2
As I mentioned in private message, please let me know if I can use your external captive portal URL to test. Because I tested for other URLs, all of them worked fine. Not sure if there is negotiation gap between your server and AP.
Joslyn0 -
Hi Joslyn,
Of course tou can use our captive portal platform to test.
Regards
Hi @yomismo2
As we discussed via the eITS system, this issue has been resolved with a date firmware. If you have any end customer needs our help to upgrade the date firmware from the backend server, please ask him enable the ZYXEL support for us.(Help > Support request). We can reach the org and help.
- 588 USG FLEX H Series
- 476 News and Release
