GS1900-24HP
hi.
need help please
I turned on the zyxel for the first time and connect through 192.168.1.1
nothing strange so far
when naming the ports and do other configuration on the system I loose access to the page 192.168.1.1
I've already turn off the switch and also reset the switch but still cannot have access
Can anyone help me?
Thank you
Can anyone help me?
Thank you
@RuiDaCruz
Welcome to Zyxel community.when naming the ports and do other configuration on the system I loose access to the page 192.168.1.1Can you be more specific about what "other configuration" is? such as VLAN or PVID?
Our current suggestion is to make sure you factory-default reset the switch by pressing reset button for over 10 secs and release.
Then you can use ZON utility to find out what exact IP the switch is.
It should be 192.168.1.1(or DHCP) if the reset does take place.
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=018017&lang=EN
Zyxel_Lucious
Only name the ports, put the data and time correct and enable security on the ports nothing elseI already done the reset button for 10 seconds about 5 times and nothing...but three ours later star working... don't understandthank you for your answer0
@RuiDaCruz
Maybe there is another device with 192.168.1.1 in the network?
You may try change the GS1900's IP to 192.168.1.2 to see if problem solves.
Zyxel_Lucious0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
