Workaround for max. 4 virtual WAN interfaces on USG 110
Best Answers
Lets take the IP on virtual interface wan1:1
If you make a routing rule say:
incoming Interface
member lan1
source IP 192.168.1.240
next hop Interface
Interface wan1
source network address translation the wan1:1 IP
But if you remove the virtual interface wan1:1 this routing rule should still work?
5 -
You were quite right. I could disable the virtual interface and it works fine. Can't explain why I ever did that, probably lack of knowledge
Again, thanks for your help0
Don't have my own subnet to play around with but surely you can do a network without virtual interfaces?
Without virtual interfaces IP traffic of your subnet is sent to WAN1? You can SNAT without virtual interfaces of a IP.
The problem is on the WAN side. I have 5 IP addresses on the same fiber, and I use both NAT + outbound routing for different services. From what I've seen, additional WAN IP addresses needs to be added as virtual WAN ports "under" WAN1.
incoming Interface
member lan1
next hop Interface
Interface wan1
5 -
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
