VPN100 - Edit Ethernet window won't load for LAN interface after upgrading to 4.60(ABFV.0)
Posts: 66  Ally Member
First Answer First Comment Friend Collector Fifth Anniversary
edited April 2021 in Security
Web GUI: Configuration - Network - Interface - Ethernet window won't load after upgrading to 4.60(ABFV.0). It stays at "loading" forever.
This applies only to LAN1 and LAN2. SFP, WAN1, WAN2, DMZ and RESERVED are loading fine.
If I fire up javascript console it gives errors on LAN1 and LAN2 popup windows.
This does not happen on other interface edit window. Only Lan1 and Lan2
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
«1
  • Posts: 3,645  Guru Member
    Try another browser or clear your browsing data.
  • Posts: 66  Ally Member
    Not a browser issue. Tested with latest Chrome, Edge and Firefox, on both desktop (4 machines, 3 windows, 1 Linux) and mobile (2 devices, android 8, 10).
    edited November 2020
    Seems to be a bug in javascript.
    Uncaught TypeError: response[("zyshdata" + i)] is undefined
        eachReader xttps://router.intranet.xxx.net/ext-js/app/common/retrieveData.js?_dc=1605741511142:103
        callback xttps://router.intranet.xxx.net/ext-js/app/common/retrieveData.js?_dc=1605741511142:74
        ExtJS 4
            callback
            onComplete
            onStateChange
            bind
  • Posts: 166  Master Member
    First Answer First Comment Third Anniversary
    You should use other PC connect to VPN100 to see the consequence.
  • Posts: 10  Freshman Member
    Same problem on other PC and router:
      Zyxel VPN 50, V4.60(ABHL.0) / 2020-10-17 04:44:36
  • Posts: 1,034  Zyxel Employee
    @xbolshe
    I tested it locally without any issue
    FW:v4.60
    Wan
    Lan
    Does this issue occur on previous firmware version?
    Also, can you private message configuration for check purpose?
  • Posts: 1  Freshman Member
    VPN 100 4.60(ABFV.0). I was not able to access Lan 1 as well. All clients are on Lan1. However, other Wan, Lan 2 were accessible and configurable.  I reset VPN 100 to factory defaults. I was able to configure Lan 1 after restart. 15 minutes later the Ethernet window would not load again. I am back on 4.35. No problems on 4.35.
    VPN100 4.60(ABFV.0) I have same issue ethernet Lan1 window won't load. Revert to V4.39(ABFV.0) and it works again.
  • Posts: 11  Freshman Member
    Hi, I'm having the same issue VPN100@4.60: LAN1 won't load, but all others works just fine.
  • Posts: 2  Freshman Member
    I'm having the same issue on my VPN100 with V4.60(ABFV.0)
    LAN1 does not load, while all others do work fine
    I've tested in on my Mac with
    - Catalina 10.15.7
    - Firefox 83.0
    - Safari 14.0
    - Chrome 87.0.4280.67
    on HTTP and HTTPS and even on an iPad with Safari
    That issue is definetively related to VPN100 and its latest release V4.60(ABFV.0)
Welcome!
Welcome!
