Workaround for max. 4 virtual WAN interfaces on USG 110
mrwee
mrwee Posts: 40  Freshman Member
edited April 2021 in Security
Just tried to add additional WAN IP addresses to my WAN1, but found that it can only have one base IP + 4 virtual interfaces. I need at least one more, is there a possible workaround / other way of accomplishing more than 4(5) WAN IP addresses on the same interface?
Best Answers
  • mrwee
    edited November 2020 Answer ✓
    You were quite right. I could disable the virtual interface and it works fine. Can't explain why I ever did that, probably lack of knowledge :).
    Again, thanks for your help
    PeterUK Posts: 3,892  Guru Member
    Don't have my own subnet to play around with but surely you can do a network without virtual interfaces?
    Without virtual interfaces IP traffic of your subnet is sent to WAN1? You can SNAT without virtual interfaces of a IP.
  • mrwee
    The problem is on the WAN side. I have 5 IP addresses on the same fiber, and I use both NAT + outbound routing for different services. From what I've seen, additional WAN IP addresses needs to be added as virtual WAN ports "under" WAN1.
  • mrwee
