[NEBULA] Cannot create Virtual Server Rule, same Public Port and Multiple Allowed Remote IPs
TCL_Support
I am trying to create new virtual server rules to expose port 443 but to only allow access from a number of defined 'Allowed Remote IP' addresses. However if I create multiple rules for public port 443 and then try to add it several times with different Allowed Remote IP entries - such as 51.140.188.39 and 88.68.100.40 - I cannot Save and there is a warning about 'overlapping ports'.
So how can we create a rule to allow multiple remote ip addresses to access the same port? This must be a very common scenario as you don't want to expose ports to the entire internet or just one remote IP address or subnet?
Hi @TCL_Support,
From you description, you need multiple Allow remote IPs for one virtual server entry.
You should be able to use " , " to configure more than one IP in that column.
For example:
Uplink Public IP Public port LAN IP Local port Allow remote IP
WAN 1 any 443 192.168.1.100 443 51.140.188.39, 88.68.100.40
Hope it helps.
Hi, I tried this, but its only possible to enter max 9 different IP in this field. How can we manage to add more? And this should be tottaly different design like Cisco Merkai Go series, where you can add one and one IP as whitelisted/allowed to access a defined port.0
- 588 USG FLEX H Series
- 476 News and Release
