SecuReporter Reportis empty.
MarcelG
MarcelG Posts: 25 image  Freshman Member
edited April 2021 in Security
I get every day the SecuReporter Report, but it is empty.
I activate it in my USG100
Whats worng ?
  • Zyxel_Stanley
    Hi @MarcelG
    You may make sure Traffic Statistics and all of Security Statistics functions are collected.
    (Monitor > System Status/ Security Statistics)
    After enabled these setting, then will able show more detail report on SecuReporter.
  • chandan
    chandan Posts: 72 image  Ally Member
    Hello @Zyxel_Stanley
    Please confirm.
    Is the screen posted above in your reply is from USG100?
    As I have different UI appears in my USG110.
  • Zyxel_Stanley
    Hi @chandan
    Can you take a screenshot on your device dashboard?
  • chandan
    Hi @chandan
    Sure.
    Please find the attached screenshot here.
  • MarcelG
    Everything Ok, I find the neccesary under "UTM Statistics" instead of "security statistics". I'm waiting for the next Repport ....
  • chandan
    @Zyxel_Stanley
    I think the UI you have posted is from ATP series firewall...
  • MarcelG
    USG110
  • MarcelG
    edited December 2020
  • Zyxel_Stanley
    Hi @MarcelG
    You may double confirm if SecuRerpoter setting is enabled.
    And also check if your device is able sync with Myzyxel.com server without any error.
    And check DNS setting is correct prevent device unable result domain name.
    If it still doesn't helpful, you may send your config to me by private message.
