SecuReporter Reportis empty.
I get every day the SecuReporter Report, but it is empty.
I activate it in my USG100
Whats worng ?
Hi @MarcelG
You may make sure Traffic Statistics and all of Security Statistics functions are collected.
(Monitor > System Status/ Security Statistics)
After enabled these setting, then will able show more detail report on SecuReporter.
Hello @Zyxel_Stanley
Please confirm.
Is the screen posted above in your reply is from USG100?
As I have different UI appears in my USG110.0 -
Everything Ok, I find the neccesary under "UTM Statistics" instead of "security statistics". I'm waiting for the next Repport ....
USG110
Hi @MarcelG
You may double confirm if SecuRerpoter setting is enabled.
And also check if your device is able sync with Myzyxel.com server without any error.
And check DNS setting is correct prevent device unable result domain name.
If it still doesn't helpful, you may send your config to me by private message.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
