Server Failure AAAA
IT_Field_Support
We have an issue on an USG40w. The local DNS is not working anymore which means that all the local dns records in the router cannot be resolved.
I made a capture and we have this error :
I tried to remove all DNS Zone Forwarder and add them, flush DNS table in router and client, rebooted the router. Cannot make if work as it do on others same router.
Thanks for help,
Davy
For your info, downgrade to 4.35 (from 4.39) fixed the problem.0
4.60 patch 1 firmware has released, it has fixed almost issues we have addressed.
You may upgrade to latest version, and check if symptom has fixed.
If it still doesn’t work, you may post your DNS PTR record and Domain Zone Forwarder settings for further check.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
