Zyxel NWA210AX slow wifi
Hi @Vict ,
Usually, the speed will be 1/2 of the link rate when there's no too much interference, so would you help to clarify below questions of the test?
1. What's the topology?
2. What's the LAN speed?
3. When you connect to the wireless to test, is there any other client use the same wireless network at the same time?
4. What's the wireless client model and the connected Tx/Rx rate?
5. Which test tool you used for the test?
6. Would you provide the logs of the NWA210AX when you did the test?
Thanks.0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
