DHCP on VLAN for Guest Wifi does not provide IP adress
I configured on my NWA1123AC-v2 2 SSID (via WebInterface)
WLAN - VLAN-ID 1 (default)
WLAN_guest - VLAN-ID 2
NWA is connected to switch HPE OfficeConnect 1920S on Port 16 which is member of VLAN-ID 2 "tagged"
on USG60 I configured VLAN -ID2 as follows:
Now I am facing the problem, that I can connect to "WLAN_guest" but get an APIPA adress, the DHCP does not provide an 192.168.2.0 address and I have no clue why....
Any ideas what I fail to see here?
many thanks
many thanks
Hi @Alex_
Here should be your topology:
Internet-------USG--------(PX)Switch(P16)--------AP.
After enabled VLAN2 interface on USG, it will also tagging out with VID2
You may make sure your both of ports on switch are member of VLAN2 and with tagging out.
Then client should able get IP address from VLAN2.
Hi Stanley
many thanks for your reply
I checked the VLAN configuration again:
I put both ports to VLAN2 but it seems the switch had a problem to save this configuration correctly.
He always dropped Port 1 to USG out of VLAN2 - nevertheless a switch restart created a remedy and now it works0
- 238 Nebula Ideas
- 6.8K Security
- 750 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
